As mentioned, currently we are implementing the Solarwinds to monitor all our existing servers (300-400) to replace our existing BMC due to the high cost in BMC licensing. Previously, we had a lot of false alarm and after upgrading the APM to the latest version, it solved the false alarm but it utilizes a lot of bandwidth. in 6 hours, it utilizes nearly 300MB of network bandwidth and once, we had turned on nearly 120 servers and the whole network just went down. FYI, we have reduced the monitoring to a very very minimal until further removal will have no reason for us to keep this going on. Eg. Exchange servers monitors 7-8 exchange services and 7 perfmon counters, SNMP is turned on.
Solarwinds support is not helpful at all saying that 'there isnt much that they can do' but utilizing 300MB in 6 hours are not something normal for a single server. We had monitor all the servers on BMC and we turned on more application monitoring than the Solarwinds but we have no issues. Since Solarwinds does not have polling servers, it might be a problem. Anyone having the same problem? Thanks.
FYI,
| Component Type | Enabled | Counter | Instance | Category\Net Service |
| Performance Counter Monitor | Yes | % Processor Time | _Total | Processor |
| Performance Counter Monitor | Yes | % Free Space | C: | LogicalDisk |
| Performance Counter Monitor | Yes | Free Megabytes | C: | LogicalDisk |
| Performance Counter Monitor | Yes | % Committed Bytes In Use | | Memory |
| Windows Service Monitor | Yes | | | MSExchangeIS |
| Windows Service Monitor | Yes | | | MSExchangeMTA |
| Windows Service Monitor | Yes | | | RESvc |
| Windows Service Monitor | Yes | | | MSExchangeSA |
| Windows Service Monitor | Yes | | | RpcSs |
| Windows Service Monitor | Yes | | | SMTPSVC |
| Windows Service Monitor | No | | | IISADMIN |
| Windows Service Monitor | No | | | IMAP4Svc |
| Performance Counter Monitor | Yes | Local Delivery | _Total | MSExchangeIS Transport Driver |
| Performance Counter Monitor | Yes | Local Queue Length | _Total | SMTP Server |
| Performance Counter Monitor | Yes | Remote Queue Length | _Total | SMTP Server |
