Hello everyone. I am working with the default APM Component Warning/Critical Monitor and have a question. I would like to be notified not only when a component goes into a Warning or Critical State, but also when a component transitions from Warning to Critical or Critical to Warning, ideally without needing to set up separate alerts. By default, at least in my environment, once the Warning threshold is tripped I am not re-notified if the status changes to Critical. Currently I am getting around this by using separate alerts for Warning and Critical, which works OK but the downside is that if the component transitions from Critical to Up I receive two Up messages (one for each alert that is cleared). It seems like my goal should be achievable and that I must just be missing something simple? Thanks in advance.
