I'm new at this so here it goes. We are running NPM 8.0 and everything is working, except one thing, APM. couple weeks ago I was doing updates on my server and there was an update for the SQL (currently using Express), that update somehow bombed out. now all of the sudden APM is not working correctly. even as my applications are posted on the event page of the website as "application stopped", they do not show in the advance alert under system manager. I checked the AlertLog table and the last entry is from when the update occured. no new entries are being created. I did uninstall SQL and reinstalled again, did the configuration wizard, etc but not working. Something strange i noticed was that when I reinstalled SQL without removing the previous installation while keeping the SQLSOLAR instance, the APM actually worked, once i rebotted the server it went back and stopped working. Does anybody has any idea what is the problem with this. I tried many different things but none seems to work. The only thing i haven't done is remove Solarwinds and reinstalled again which i never done it. Any suggestion will be appreciated.
