I have documented the whole solution here:
The Magic of SWQL: Create "All Components With Problems" Resource With Clickable Links, Status Icons and Even Hovers As …
Hi All,
This is pretty basic question but I could not find the answer. I need to be able to output in SWQL MESSAGE and STATISTIC values for the component. Can anyone help to modify below SWQL query to do so?
Desirable Output:
| NAME | STATUS | STATISTIC | MESSAGE |
SELECT ComponentName AS NAME, StatusDescription AS STATUS FROM Orion.APM.Component WHERE ApplicationID IN ('995','996') AND StatusDescription IN ('Warning','Critical') |
Thank You,
Alex
