Given: We currently have NPM 9.1 running in production on a MS-SQL 2000 cluster environment.
We would like to install NCM 5.0 on the same application server for consolidated syslog information.
Forgive my ignorance, the questions I have are more from the database/design perspective:
Is it possible to run the NCM 5.0 product on the same application server that NPM 9.1 is on, but utilize a different backend database server from the NPM product, as illlustrated:
NPM 9.1 on Server APP1, talking to MS-SQL 2000 DB on Server DB1
NCM 5.0 on Server APP1 talking to MS-SQL 2005 DB on Server DB2
The reason I ask is because we anticipate migrating some point in the future to MS-SQL 2005 (64-bit), and would like bring up the NCM application using MS-SQL 2005 for it's database in order to save a migration later.
We would then at some point in the future migrate the NPM database over to the same MS-SQL 2005 cluster, which also begs the question does that migration take a re-install of NPM, or just move the database and re-run the database wizard to point to the new location of the DB?
Thanks in advance for your help!
Regards,
Bob
