Hoy many ever users supported the NPM web portal??
Mavila,
Orion is not going to limit you on the number of simultaneous users who can be connected to the Orion web site at any given time. The limitation would really be in the hardware supporting your Orion solution. The end result of a heavy load on your web server would be slower performance on the website. If you plan on having lots of users in the website, you should consider distributing the web load to a server that is not your primary Orion server with the Orion Web Server Engine.
Thanks, Jason HensonLoop1 Systemswww.Loop1Systems.com
Thank You
