Hello all. I am failry new to Solarwinds. I am setting up our routers in Orion and NCM. I was able to get the config comparison exceptions setup for most evertying based on what I've learned from Thwack so thanks for that. However, there is one that I have not been able to figure out. These are Cisco 4500X (I have 3 of them). The running config has the line in it "ip vrf Liin-vrf". The startup config does NOT. Even if I do a write mem, it stays like this. I have attached the screen shot from the Config Comparison on one of the 4500s showing this. I have tried the following regex in the NCM comparison criteria settings and NONE of them worked:
[ \t\r\n\v\f]ip vrf Liin-vrf[ \t\r\n\v\f]* - nope
^*ip vrf Liin-vrf* - nope
^ip vrf - nope
[ \t\r\n\v\f]ip vrf*[ \t\r\n\v\f] - nope
[ \t\r\n\v\f]ip vrf[ \t\r\n\v\f] - nope
^ip vrf Liin-vrf - nope
I am hoping one of you with experience in this can help me get this figured out.
Rick
