We use the Cirrus Policy Reporter extensively for doing Cisco configuration compliance reporting – and it’s been working well for us.
I now want to extend compliance reporting into our QOS polices – but I’ve run into an issue that has me stumped.
Hopefully there is a genius around who can help!
The easiest way to explain my problem is with an example…
I want to be able to verify the service policy applied to a number of interfaces, so I added some detail to the interface description that would enable me to check that the correct service-policy was applied (so far so good) – example config below....
interface GigabitEthernet0/1.7
description WANLink-if.subintf_wan(native)
encapsulation dot1Q 7
ip address xxx.xxx.xxx.xxx 255.255.255.252
no ip redirects
no ip proxy-arp
service-policy output Shape-native-1
Some devices also may have multiple VRF’s on them with interfaces like the following…
interface GigabitEthernet0/1.107
description WANLink-if.subintf_wan(prod-user)
encapsulation dot1Q 107
no ip redirects
no ip proxy-arp
service-policy output Shape-prod-user-1
and others will have crypto…
interface GigabitEthernet0/2.10
description Dist-if.Crypto(native)
ip address xxx.xxx.xxx.xxx 255.255.255.248
no ip redirects
no ip proxy-arp
service-policy input Police-To-VAM2+
The problem is, I need a way to write a regex expression that looks for the description and determines if the correct service-policy is applied (which I can do), but an expression that doesn’t create a policy violation if the description isn’t found (e.g. if the particular vrf isn’t configured on the router).
Can anyone point me in the right direction??
Dave.
