I have a fairly simple powershell script (see below) that ends with "exit 0".
Yet when I test it I get a "Testing on node {node name}: failed with 'Unknown' status.
Any idea why it is getting an 'Unknown' status?
Thank you
Powershell script that I'm running:
function Get-DOSSqlData($connectionString, $SelectSql)
Write-Verbose 'Get-DOSSqlData: Starting'
$connection = New-Object System.Data.SqlClient.SqlConnection($connectionString)
$connection.Open()
$command = $connection.CreateCommand()
$command.CommandText = $SelectSql
$command.CommandTimeout = 10
$adapter = New-Object System.Data.SqlClient.SqlDataAdapter $command
$dataset = New-Object System.Data.DataSet
$adapter.Fill($dataset) | out-null
If ($null -ne $dataset.Tables[0])
$table = $dataset.Tables[0]
ElseIf ($table.Rows.Count -eq 0)
$table = New-Object System.Collections.ArrayList
$connection.Close()
Write-Verbose 'Get-DOSSqlData: Returning'
return $table
$env:UserName
$env:UserDomain
$env:ComputerName
Write-Host "testing"
$metadataConnectionString = "Server=localhost;Database=master;Trusted_Connection=True;MultipleActiveResultSets=True;Connect Timeout=10"
$result1 = Get-DOSSqlData $metadataConnectionString "SELECT getdate()"
Write-Host $result1
Write-Host "done"
exit 0
