Hermann
Traces
[18/11/2008 9:10:43 AM] Menu-Based mode=False
-->StateChange: Connecting to server<--
-->StateChange: Connected to server - idle<--
[18/11/2008 9:10:43 AM] Solarwinds.Net SWTelnet9 Version 9.0.29
[18/11/2008 9:10:43 AM] Connected!
[18/11/2008 9:10:43 AM] -->
[18/11/2008 9:10:43 AM] --> telnet session telnet0 on /dev/ptyb0
[18/11/2008 9:10:43 AM] ProcessLogin State: 0
[18/11/2008 9:10:44 AM] --->login:
[18/11/2008 9:10:44 AM] ProcessLogin State: 0
[18/11/2008 9:10:44 AM] UserName Prompt detected: login:
[18/11/2008 9:10:44 AM] Send user name
[18/11/2008 9:10:44 AM] <-- admin
[18/11/2008 9:10:44 AM] --->a
[18/11/2008 9:10:44 AM] ProcessLogin State: 2
[18/11/2008 9:10:44 AM] --> dmin
[18/11/2008 9:10:44 AM] --> password:
[18/11/2008 9:10:44 AM] Standard password prompt detected
[18/11/2008 9:10:44 AM] <-- ###### (hidden)
[18/11/2008 9:10:44 AM] ProcessLogin State: 3
[18/11/2008 9:10:44 AM] --> ExtremeXOS
[18/11/2008 9:10:44 AM] --> Copyright (C) 2000-2007 Extreme Networks. All rights reserved.
[18/11/2008 9:10:44 AM] --> Protected by US Patent Nos: 6,678,248; 6,104,700; 6,766,482; 6,618,388; 6,034,957; 6,859,438; 6,912,592; 6,954,436; 6,977,891; 6,980,550; 6,981,174; 7,003,705; 7,017,082; 7,046,665; 7,126,923; 7,142,509; 7,149,217; 7,152,124; 7,154,861.
[18/11/2008 9:10:44 AM] --> ==============================================================================
[18/11/2008 9:10:44 AM] --> Press the <tab> or '?' key at any time for completions.
[18/11/2008 9:10:44 AM] --> Remember to save your configuration changes.
[18/11/2008 9:10:44 AM] --> * BorderRtr.1 #
[18/11/2008 9:10:44 AM] Command mode prompt detected at LoginState_Password
[18/11/2008 9:10:44 AM] Prompt is being set to : * BorderRtr.1 #
[18/11/2008 9:10:44 AM] Logged into Router
[18/11/2008 9:10:44 AM] Start check prompt for menu-base device
[18/11/2008 9:10:44 AM] Process Line = <>
[18/11/2008 9:10:45 AM] --->* BorderRtr.1 #
[18/11/2008 9:10:45 AM] Start check prompt for menu-base device
[18/11/2008 9:10:45 AM] Process Line = <* BorderRtr.1 # >
[18/11/2008 9:10:45 AM] Fuzzy match detector start detecting prompt. String1=*borderrtr.1# String2=*borderrtr.1#
[18/11/2008 9:10:45 AM] <-- disable clipaging session
[18/11/2008 9:10:45 AM] --> disable clipaging session
[18/11/2008 9:10:45 AM] Complete buffer is detected - save all lines to eacho buffer
[18/11/2008 9:10:45 AM] Echo not detected yet. push back data to echo buffer, EchoBuffer = <<<disable clipaging session
[18/11/2008 9:10:45 AM] Start detecting command echo in echo buffer..
[18/11/2008 9:10:45 AM] Echo is detected, EchoBuffer = <<<disable clipaging session
[18/11/2008 9:10:45 AM] Error removing prompt. RegEx=*\s*\n* \s*\n*B\s*\n*o\s*\n*r\s*\n*d\s*\n*e\s*\n*r\s*\n*R\s*\n*t\s*\n*r\s*\n*.\s*\n*1\s*\n* \s*\n*#\s*\n* \s*\n* PromptLine=* BorderRtr.1 #
[18/11/2008 9:10:45 AM] Echo and prompt is removed if they exist, out buffer = <<<>>>
[18/11/2008 9:10:45 AM] --> ^
[18/11/2008 9:10:45 AM] --> %% Invalid input detected at '^' marker.
[18/11/2008 9:10:45 AM] --> * BorderRtr.2 #
[18/11/2008 9:10:45 AM] Process Line = < ^>
[18/11/2008 9:10:45 AM] Fuzzy match detector start detecting prompt. String1=^ String2=*borderrtr.1#
[18/11/2008 9:10:45 AM] Save Command Output: ^
[18/11/2008 9:10:45 AM] Process Line = <>
[18/11/2008 9:10:45 AM] Process Line = <%% Invalid input detected at '^' marker.>
[18/11/2008 9:10:45 AM] Fuzzy match detector start detecting prompt. String1=%%invalidinputdetectedat'^'marker. String2=*borderrtr.1#
[18/11/2008 9:10:45 AM] Save Command Output: %% Invalid input detected at '^' marker.
[18/11/2008 9:10:45 AM] Process Line = <* BorderRtr.2 # >
[18/11/2008 9:10:45 AM] Fuzzy match detector start detecting prompt. String1=*borderrtr.2# String2=*borderrtr.1#
[18/11/2008 9:10:45 AM] <-- show conf detail
[18/11/2008 9:10:45 AM] --> show conf detail
[18/11/2008 9:10:45 AM] Echo not detected yet. push back data to echo buffer, EchoBuffer = <<<show conf detail
[18/11/2008 9:10:45 AM] Echo is detected, EchoBuffer = <<<show conf detail
[18/11/2008 9:10:45 AM] TimerTick: mstrData=<> State=3 - Connected to server - idle
[18/11/2008 9:10:45 AM] Pending Disconnect = False
[18/11/2008 9:10:45 AM] --> * BorderRtr.3 #
[18/11/2008 9:10:45 AM] Process Line = <* BorderRtr.3 # >
[18/11/2008 9:10:45 AM] Fuzzy match detector start detecting prompt. String1=*borderrtr.3# String2=*borderrtr.1#
[18/11/2008 9:10:45 AM] SendNextCommand Done: Disconnecting
[18/11/2008 9:10:47 AM] TimerTick: mstrData=<* BorderRtr.3 # > State=3 - Connected to server - idle
[18/11/2008 9:10:47 AM] Pending Disconnect = True
[18/11/2008 9:10:47 AM] Disconnected - From: 172.31.1.9
[18/11/2008 9:10:13 AM] Menu-Based mode=False
[18/11/2008 9:10:13 AM] Got HostFingerPrint: 58:14:9f:34:0d:6f:77:a2:44:91:fd:77:4b:95:6e:2b
[18/11/2008 9:10:13 AM] Solarwinds.Net SWTelnet9 Version 9.0.29
[18/11/2008 9:10:13 AM] Connected!
-->StateChange: Disconnected from server<--
[18/11/2008 9:10:13 AM] Disconnected - From: 10.61.208.1
Device Template used:
<!-- edited with XML Spy v4.4 U (http://www.xmlspy.com) by Brian K Rogers (Solarwinds.Net) -->
<!--Copyright 2005 SolarWinds.Net All rights reserved-->
<Configuration-Management Device="Extreme Devices" SystemOID=" 1.3.6.1.4.1.1916">
<Commands>
<Command Name="RESET" Value="disable clipaging"/>
<Command Name="Reboot" Value="restart${CRLF}y"/>
<Command Name="EnterConfigMode" Value=""/>
<Command Name="ExitConfigMode" Value=""/>
<Command Name="Startup" Value="conf detail"/>
<Command Name="Running" Value="conf detail"/>
<Command Name="DownloadConfig" Value="show ${ConfigType}"/>
<Command Name="UploadConfig" Value=""/>
<Command Name="EraseConfig" Value=""/>
<Command Name="SaveConfig" Value="save pri${CRLF}y${CRLF}save sec${CRLF}y"/>
<Command Name="Version" Value="show version"/>
</Commands>
</Configuration-Management>
