Hi there,
I've been asked to put together a DNS location monitor using SAM. Not 100% i can actually do it this way, but basically the requirement is:
On the dashboard for our websites to have the primary location of the sites listed in a table.
There are 3 sites that could host each of the sites, so really all i need is something that will do an nslookup for the IP - and return a location (i.e. London) based on that IP. The only other option is to try and do it via SNMP on the Stingray Traffic Managers, but i havent had much luck with the MIB / SNMP on that!
Any pointers would be great
Cheers
