I have added Veeam Backup and WSUS nodes with their standard templates to monitor their status but both applications are giving errors.
Solarwinds support is asking to check in the application but dont know what to check and where
abid.ali Did you set up WinRM and PowerShell as indicated in the B&R template article? I will probably be setting this up in the next week so I may be able to assist if you are still having the issue.
Veeam Backup and Replication Server
