You can run putty.exe from c:\Users\<username>\AppData\Roaming\Solar-PuTTY\putty.exe, set the font size, colors, and other appearance you want to use, and save it to 'Default Settings'. Solar-PuTTY then loads the Putty’s setting as a default setting for all sessions.
