Hi Support
I would like to see better filtering in the NCM intergartion website with NPM as you cannot filter any nodes via any custom properties in the web. In NPM you can do this but it would seem that in the integration NCM manage nodes there are only 5 options or fileds , which seems an oversight by engineering. Can this please be fixed as you glued the two products together , but yet you dont allow the flexibility of the integration that should be there from day one.
URL where the issue resides.
http://<ipaddress>/Orion/NCM/Admin/Nodes/NodeMapping.aspx
Kind Regards
James
