I have installed Cirrus 4, which also does an install of MS SQLExpress. The install didn't really ask for any specifics other than an sa password which I supplied. Upon completion of the install, I fired up Cirrus which brought up the new database wizard. I am unable to create a new database and am wondering if SQLExpress got installed correctly or at the very least configured correctly. When I try to create a new database, it doesn't matter whether I put in (local)\SQLExpress or servername\SQLExpress, it errors out. Basically telling me that the instance or server doesn't exist. If I just put the server name in it proceeds to the next screen as though it is creating the DB but errors out there as well. I need help to make sure that I have SQLExpress configured correctly and how I can check whether it is. I've tried everything that the knowledge base suggests to no avail. What do I need to do to get this thing running?
