I'm pretty sure this can't be done, but if i was completely sure I wouldn't be posting here
In NPM 10.3 (and all the older versions), it would be SO simple and helpful if, when configuring Basic Alerts, if you could resize the 'Edit Alert' window, at least while viewing the 'Monitored Network Objects' tab, so that you could see more than 18 network objects listed at a time. You can resize the window, sure, but the size of the scrollbox window contents remains frozen at a view of 18 lines. Is there any kind of a program or registry tweak I can hit to change that? It seems like such an arbitrary and tedious limitation. Thanks in advance for any feedback
-John Jackson
