Hi Guys,
I know I can turn to you guys for some valuable suggestions.
We are coming up with a new office and trying to get all the switches installed remotely. So the requirement is to -
1) Connect the OOB (Out of Band) 4G console server.
2) Connect the switches to this OOB 4G console.
3) Try and use NCM scripts to assign First IP to First Console Port switch --> Second IP to the Second Console -----> Nth IP to the Nth switch connected to console port.
4) Once the switches have IP's and as they'll be physically connected as well, use NCM to do the rest of the configuration for the basic connectivity.
5) Once that is done, then use the regular NCM feature to push the configuration to all those connected switches.
Simple ?? Questions? Suggestion?
Most welcome.
Thanks & Regards,
Solarwinds fan
