Hello All
Due to the wide variation of Vendors we are managing for one customer. I have had to create several Custom Properties in order for Reporting to come out showing usable information.
For example -- I created a customer property called 'Firmware' where I would like to pull information from the database and fill in the Version number only. The table pulled from would be different for a couple of Vendor devices because these vendors chose to put proprietary data in different, non-standard tables.
The big question is...Can I use some of the built in Node Variables to pull that data and fill in the fields?
Next question ... Can I use SQL Statement based variable to pull data from non-standard tables and fill in the fields?
So far...all of my attempts have ended with putting the ${VARIABLE} in plain text into the Field, and not pulling the data for the Variable.
I can explain further if needed....hopefully this will be enough to get the answers I need.
Please provide example Variable and/or example SQL Statement variable that work so I can see where I went wrong.
Jeff Singletohn
Motorola Solutions Inc.
