I am having a few issues. I am trying to monitor some oracle instances. The Solarwinds oracle monitoring tool didn't work for me. So I downloaded the 32 and 64 bit versions of ODP.NET and I get the following error when I run the test in SAM.
Could someone assist me in this endeavour please?
The Oracle Client software must be properly installed to use the Oracle QA Monitor.
Component uses following Oracle Client Driver: ODP_NET. This particular Oracle Client software can be downloaded from the
Oracle ODP.Net webpage.
Underlying exception message is: 'Unable to find the requested .Net Framework Data Provider. It may not be installed.'.
