G'Day,
I apologize, as I realize this must be posted or documented somewhere, but I can't find what I'm specifically looking for. I'm trying to figure how advanced alerts triggers nest. I know it's not a typical if-then-else structure - that would be too easy. I've also played with the easy stuff, like if nodename=this and status is either this or that, but when I get into more complicated territory, I'm either not understanding how to nesting works, or Orion simply cannot do what I want, something like:
Trigger Alert when all of the following apply
Node Name is equal to SERVERA
Node Name is equal to SERVERB
Application Name is equal to APPA_Connection
Trigger Allert when any of the following apply
Application Status is not equal to UP
Application Name is equal to APPA_User_Experience
Response Time is greater than 600
By my reckoning, that should work out to: if application APPA is down, or has a slow response time, on both nodes, then alert. This is not even the whole picture. I also need to trigger an alert if both nodes are down, but I guess the connection monitor would take care of that too.
Anyway, can anyone point me to some documentation on nesting in advanced alerts, please? Failing that, can anyone give me a quick primer?
Thanx
Stephen
P.S. I realize the above structure is flawed. The nodename cannot be both SERVERA and SERVERB. It's just an example of the logic I need.
