How do I set the Polling Engine to restart autmatically after I reboot the SW Orion server??
When I bring up System Manager, I have to manually start the Polling Engine after a reboot of the server.
Thank you
This Should not happen
The service should start automatically when you reboot the Server . Check the Services Option in computer management
Ensure that the Service is set to Automatic on start-up.
You may want to try a reboot and before you open system manager Use Orion Service manager option (Under Advanced Features)
and See if all services are Running
-j
