Hello,
please does NTA monitor uptime and downtime internet links and monitor user band width consumption? if it does not, could you recommend one for me that does? and also is it compatible with checkpoint
NPM is really used to monitor the uptime/downtime of internet links. Depending on your network configuration NTA will let you know what device is using up the bandwidth, what it is communicating with, what protocol its using, etc. So it will help you figure out what is taking up the bandwidth and what exactly its doing so you can figure out how to fix it by policing the traffic or whatever.
