Hi all,
I had wrote the following template which suppose to downlad config from an Ericsson X25 device called PFA.
<Configuration-Management Device="PFA Devices" SystemOID=" 1.3.6.1.4.1.193.5.3">
<Commands>
<Command Name="RESET" Value=""/>
<Command Name="EnterConfigMode" Value=""/>
<Command Name="ExitConfigMode" Value=""/>
<Command Name="Startup" Value=""/>
<Command Name="Running" Value=""/>
<Command Name="DownloadConfig" Value="lipop;" RegEx=">" Delay="300"/>
<Command Name="UploadConfig" Value=""/>
<Command Name="DownloadConfigIndirect" Value=""/>
<Command Name="UploadConfigIndirect" Value=""/>
<Command Name="Version" Value="" RegEx=">"/>
<Command Name="MenuBased" Value="false"/>
<Command Name="EnableIdentifier" Value=">"/>
</Commands>
</Configuration-Management>
For any reason it refuse to work.
The NCM GUI sends me: "Connectivity issues discarding config file." output.
I'm attaching the trace log of the connection.
[12/31/2009 8:03:56 PM] -----------------NCM 5.5.2 -------------------
[12/31/2009 8:03:56 PM] Login Attempts: 1
[12/31/2009 8:03:56 PM] Custom UserName Prompt:
[12/31/2009 8:03:56 PM] Device Template: PFA-1.3.6.1.4.1.193.5.3.ConfigMgmt-Commands
[12/31/2009 8:03:56 PM] System Name: Lab_PFA
[12/31/2009 8:03:56 PM] System Description: Ericsson PFA V5.1.1 ID:491.399 R37 DATE:2000-04-12 TIME:16402
[12/31/2009 8:03:56 PM] System OID: 1.3.6.1.4.1.193.5.3
[12/31/2009 8:03:56 PM] OS Image:
[12/31/2009 8:03:56 PM] OS Version:
[12/31/2009 8:03:56 PM] Menu-Based mode=False
-->StateChange: Connecting to server<--
-->StateChange: Connected to server - idle<--
[12/31/2009 8:03:56 PM] Solarwinds.Net SWTelnet9 Version 9.0.28
[12/31/2009 8:03:56 PM] Connected!
[12/31/2009 8:03:56 PM] -->
[12/31/2009 8:03:56 PM] --> TELNET Daemon: Connected.
[12/31/2009 8:03:56 PM] ProcessLogin State: 0
[12/31/2009 8:03:56 PM] --> Please ensure that your TELNET client is using "line" mode with local echo.
[12/31/2009 8:03:58 PM] TimerTick: mstrData=<> State=3 - Connected to server - idle
[12/31/2009 8:03:58 PM] Pending Disconnect = False
[12/31/2009 8:03:58 PM] Sending to get a banner!
[12/31/2009 8:03:58 PM] <--
[12/31/2009 8:03:58 PM] --->USERNAME:
[12/31/2009 8:03:58 PM] ProcessLogin State: 0
[12/31/2009 8:03:58 PM] UserName Prompt detected: USERNAME:
[12/31/2009 8:03:58 PM] Send user name
[12/31/2009 8:03:58 PM] <-- ****
[12/31/2009 8:03:58 PM] --->PASSWORD:
[12/31/2009 8:03:58 PM] ProcessLogin State: 2
[12/31/2009 8:03:58 PM] Standard password prompt detected
[12/31/2009 8:03:58 PM] -->
[12/31/2009 8:03:58 PM] --> UnSaved:Lab_Pfa>
[12/31/2009 8:03:58 PM] ProcessLogin State: 3
[12/31/2009 8:03:58 PM] Command mode prompt detected at LoginState_Password
[12/31/2009 8:03:58 PM] Prompt is being set to : UnSaved:Lab_Pfa>
[12/31/2009 8:03:58 PM] Logged into Router
[12/31/2009 8:03:58 PM] --->UnSaved:Lab_Pfa>
[12/31/2009 8:03:58 PM] Start check prompt for menu-based device
[12/31/2009 8:03:58 PM] Process Line = <UnSaved:Lab_Pfa>>
[12/31/2009 8:03:58 PM] Fuzzy match detector start detecting prompt. String1=unsaved:lab_pfa> String2=unsaved:lab_pfa>
[12/31/2009 8:03:58 PM] <-- lipop;
[12/31/2009 8:04:00 PM] --> PORT STATUS INFORMATION
[12/31/2009 8:04:00 PM] --> PORT NP LP PP PROTOCOL USER RATE ADDR
[12/31/2009 8:04:00 PM] --> --------------------------------------------------------------------------
[12/31/2009 8:04:00 PM] --> 1-1-1-2 MB MB MB X25/X25/V24 ROT=2 2M
[12/31/2009 8:04:00 PM] --> 1-1-1-3 WO WO WO X25/X25/V24 ROT=3 64K
[12/31/2009 8:04:00 PM] --> 1-1-1-4 WO WO WO X25/X25/V24 ROT=4 1M
[12/31/2009 8:04:00 PM] --> 1-1-1-6 WO WO WO X25/X25/V24 ROT=6 64K
[12/31/2009 8:04:00 PM] Complete buffer is detected - save all lines to echo buffer
[12/31/2009 8:04:00 PM] Echo not detected yet. Push back data to echo buffer, EchoBuffer = <<<PORT STATUS INFORMATION
[12/31/2009 8:04:00 PM] Start detecting command echo in echo buffer...
[12/31/2009 8:04:00 PM] Start check prompt for menu-based device
[12/31/2009 8:04:00 PM] Process Line = <PORT STATUS INFORMATION>
[12/31/2009 8:04:00 PM] Fuzzy match detector start detecting prompt. String1=portstatusinformation String2=unsaved:lab_pfa>
[12/31/2009 8:04:00 PM] Process Line = <>
[12/31/2009 8:04:00 PM] Process Line = <PORT NP LP PP PROTOCOL USER RATE ADDR>
[12/31/2009 8:04:00 PM] Fuzzy match detector start detecting prompt. String1=portnplpppprotocoluserrateaddr String2=unsaved:lab_pfa>
[12/31/2009 8:04:00 PM] Process Line = <-------------------------------------------------------------------------->
[12/31/2009 8:04:00 PM] Fuzzy match detector start detecting prompt. String1=-------------------------------------------------------------------------- String2=unsaved:lab_pfa>
[12/31/2009 8:04:00 PM] Process Line = <1-1-1-2 MB MB MB X25/X25/V24 ROT=2 2M >
[12/31/2009 8:04:00 PM] Fuzzy match detector start detecting prompt. String1=1-1-1-2mbmbmbx25/x25/v24rot=22m String2=unsaved:lab_pfa>
[12/31/2009 8:04:00 PM] Process Line = <1-1-1-3 WO WO WO X25/X25/V24 ROT=3 64K >
[12/31/2009 8:04:00 PM] Fuzzy match detector start detecting prompt. String1=1-1-1-3wowowox25/x25/v24rot=364k String2=unsaved:lab_pfa>
[12/31/2009 8:04:00 PM] Process Line = <1-1-1-4 WO WO WO X25/X25/V24 ROT=4 1M >
[12/31/2009 8:04:00 PM] Fuzzy match detector start detecting prompt. String1=1-1-1-4wowowox25/x25/v24rot=41m String2=unsaved:lab_pfa>
[12/31/2009 8:04:00 PM] Process Line = <1-1-1-6 WO WO WO X25/X25/V24 ROT=6 64K >
[12/31/2009 8:04:00 PM] Fuzzy match detector start detecting prompt. String1=1-1-1-6wowowox25/x25/v24rot=664k String2=unsaved:lab_pfa>
[12/31/2009 8:04:00 PM] --> 1-1-1-7 AB AB HB X25/X25 ROT=7
[12/31/2009 8:04:00 PM] --> 1-1-1-8 WO WO WO X25/X25/V24 ROT=8 1M
[12/31/2009 8:04:00 PM] --> 1-1-1-9 AB AB WO X25/X25/V24 ROT=9 256K
[12/31/2009 8:04:00 PM] --> 1-1-1-12 AB AB AB X25/X25/V24 ROT=12 256K
[12/31/2009 8:04:00 PM] --> 1-1-1-13 WO WO WO X25/X25/V24 ROT=13 512K
[12/31/2009 8:04:00 PM] --> 1-1-1-14 AB AB AB X25/X25/V24 ROT=14 256K
[12/31/2009 8:04:00 PM] --> 1-1-1-15 WO WO WO X25/X25/V24 ROT=15 2M
[12/31/2009 8:04:00 PM] --> 1-1-1-17 AB AB AB X25/X25/V24 ROT=17 64K
[12/31/2009 8:04:00 PM] --> 1-1-1-18 AB AB AB X29/X28/ASYNC NTN=900100018 9600
[12/31/2009 8:04:00 PM] --> PORT FP PP PROTOCOL USER RATE
[12/31/2009 8:04:00 PM] --> SVC LMI
[12/31/2009 8:04:00 PM] --> 1-1-1-1 NA AB AB FNI/G703 NTN=90010000010 2M
[12/31/2009 8:04:00 PM] --> 1-1-1-10 AB AB AB FNI/G703 NTN=90010000030 2M
[12/31/2009 8:04:00 PM] --> 1-1-1-11 AB AB AB FNI/G703 NTN=90010000050 2M
[12/31/2009 8:04:00 PM] --> PORT FR-NP FR-LP PROTOCOL NP USER FR USER
[12/31/2009 8:04:00 PM] --> ------------------------------------------------------------------------------
[12/31/2009 8:04:00 PM] --> 1-1-1-XF1 AB AB X75/X75 ROT=1 NTN=90010000020
[12/31/2009 8:04:00 PM] --> 1-1-1-XF10 AB AB X75/X75 ROT=10 NTN=90010000040
[12/31/2009 8:04:00 PM] --> 1-1-1-XF11 AB AB X75/X75 ROT=11 NTN=90010000060
[12/31/2009 8:04:00 PM] --> PORT NP LP NI LA PROTOCOL USER RATE
[12/31/2009 8:04:00 PM] --> 1-1-0-1 NA WO ETHER MAC=00.00.ff.1a.01.8e 10M
[12/31/2009 8:04:00 PM] --> 1-1-0-1 WO NA IP IP=172.20.6.40
[12/31/2009 8:04:00 PM] --> END
[12/31/2009 8:04:00 PM] --> UnSaved:Lab_Pfa>
[12/31/2009 8:04:00 PM] Incomplete buffer with prompt is detected - save all lines to echo buffer
SVC LMI
END
UnSaved:Lab_Pfa>
[12/31/2009 8:04:00 PM] Process Line = <1-1-1-7 AB AB HB X25/X25 ROT=7 >
[12/31/2009 8:04:00 PM] Fuzzy match detector start detecting prompt. String1=1-1-1-7ababhbx25/x25rot=7 String2=unsaved:lab_pfa>
[12/31/2009 8:04:00 PM] Process Line = <1-1-1-8 WO WO WO X25/X25/V24 ROT=8 1M >
[12/31/2009 8:04:00 PM] Fuzzy match detector start detecting prompt. String1=1-1-1-8wowowox25/x25/v24rot=81m String2=unsaved:lab_pfa>
[12/31/2009 8:04:00 PM] Process Line = <1-1-1-9 AB AB WO X25/X25/V24 ROT=9 256K >
[12/31/2009 8:04:00 PM] Fuzzy match detector start detecting prompt. String1=1-1-1-9ababwox25/x25/v24rot=9256k String2=unsaved:lab_pfa>
[12/31/2009 8:04:00 PM] Process Line = <1-1-1-12 AB AB AB X25/X25/V24 ROT=12 256K >
[12/31/2009 8:04:00 PM] Fuzzy match detector start detecting prompt. String1=1-1-1-12abababx25/x25/v24rot=12256k String2=unsaved:lab_pfa>
[12/31/2009 8:04:00 PM] Process Line = <1-1-1-13 WO WO WO X25/X25/V24 ROT=13 512K >
[12/31/2009 8:04:00 PM] Fuzzy match detector start detecting prompt. String1=1-1-1-13wowowox25/x25/v24rot=13512k String2=unsaved:lab_pfa>
[12/31/2009 8:04:00 PM] Process Line = <1-1-1-14 AB AB AB X25/X25/V24 ROT=14 256K >
[12/31/2009 8:04:00 PM] Fuzzy match detector start detecting prompt. String1=1-1-1-14abababx25/x25/v24rot=14256k String2=unsaved:lab_pfa>
[12/31/2009 8:04:00 PM] Process Line = <1-1-1-15 WO WO WO X25/X25/V24 ROT=15 2M >
[12/31/2009 8:04:00 PM] Fuzzy match detector start detecting prompt. String1=1-1-1-15wowowox25/x25/v24rot=152m String2=unsaved:lab_pfa>
[12/31/2009 8:04:00 PM] Process Line = <1-1-1-17 AB AB AB X25/X25/V24 ROT=17 64K >
[12/31/2009 8:04:00 PM] Fuzzy match detector start detecting prompt. String1=1-1-1-17abababx25/x25/v24rot=1764k String2=unsaved:lab_pfa>
[12/31/2009 8:04:00 PM] Process Line = <1-1-1-18 AB AB AB X29/X28/ASYNC NTN=900100018 9600 >
[12/31/2009 8:04:00 PM] Fuzzy match detector start detecting prompt. String1=1-1-1-18abababx29/x28/asyncntn=9001000189600 String2=unsaved:lab_pfa>
[12/31/2009 8:04:00 PM] Process Line = <PORT FP PP PROTOCOL USER RATE>
[12/31/2009 8:04:00 PM] Fuzzy match detector start detecting prompt. String1=portfpppprotocoluserrate String2=unsaved:lab_pfa>
[12/31/2009 8:04:00 PM] Process Line = < SVC LMI>
[12/31/2009 8:04:00 PM] Fuzzy match detector start detecting prompt. String1=svclmi String2=unsaved:lab_pfa>
[12/31/2009 8:04:00 PM] Process Line = <1-1-1-1 NA AB AB FNI/G703 NTN=90010000010 2M >
[12/31/2009 8:04:00 PM] Fuzzy match detector start detecting prompt. String1=1-1-1-1naababfni/g703ntn=900100000102m String2=unsaved:lab_pfa>
[12/31/2009 8:04:00 PM] Process Line = <1-1-1-10 AB AB AB FNI/G703 NTN=90010000030 2M >
[12/31/2009 8:04:00 PM] Fuzzy match detector start detecting prompt. String1=1-1-1-10abababfni/g703ntn=900100000302m String2=unsaved:lab_pfa>
[12/31/2009 8:04:00 PM] Process Line = <1-1-1-11 AB AB AB FNI/G703 NTN=90010000050 2M >
[12/31/2009 8:04:00 PM] Fuzzy match detector start detecting prompt. String1=1-1-1-11abababfni/g703ntn=900100000502m String2=unsaved:lab_pfa>
[12/31/2009 8:04:00 PM] Process Line = <PORT FR-NP FR-LP PROTOCOL NP USER FR USER>
[12/31/2009 8:04:00 PM] Fuzzy match detector start detecting prompt. String1=portfr-npfr-lpprotocolnpuserfruser String2=unsaved:lab_pfa>
[12/31/2009 8:04:00 PM] Process Line = <------------------------------------------------------------------------------>
[12/31/2009 8:04:00 PM] Fuzzy match detector start detecting prompt. String1=------------------------------------------------------------------------------ String2=unsaved:lab_pfa>
[12/31/2009 8:04:00 PM] Process Line = <1-1-1-XF1 AB AB X75/X75 ROT=1 NTN=90010000020>
[12/31/2009 8:04:00 PM] Fuzzy match detector start detecting prompt. String1=1-1-1-xf1ababx75/x75rot=1ntn=90010000020 String2=unsaved:lab_pfa>
[12/31/2009 8:04:00 PM] Process Line = <1-1-1-XF10 AB AB X75/X75 ROT=10 NTN=90010000040>
[12/31/2009 8:04:00 PM] Fuzzy match detector start detecting prompt. String1=1-1-1-xf10ababx75/x75rot=10ntn=90010000040 String2=unsaved:lab_pfa>
[12/31/2009 8:04:00 PM] Process Line = <1-1-1-XF11 AB AB X75/X75 ROT=11 NTN=90010000060>
[12/31/2009 8:04:00 PM] Fuzzy match detector start detecting prompt. String1=1-1-1-xf11ababx75/x75rot=11ntn=90010000060 String2=unsaved:lab_pfa>
[12/31/2009 8:04:00 PM] Process Line = <PORT NP LP NI LA PROTOCOL USER RATE>
[12/31/2009 8:04:00 PM] Fuzzy match detector start detecting prompt. String1=portnplpnilaprotocoluserrate String2=unsaved:lab_pfa>
[12/31/2009 8:04:00 PM] Process Line = <1-1-0-1 NA WO ETHER MAC=00.00.ff.1a.01.8e 10M >
[12/31/2009 8:04:00 PM] Fuzzy match detector start detecting prompt. String1=1-1-0-1nawoethermac=00.00.ff.1a.01.8e10m String2=unsaved:lab_pfa>
[12/31/2009 8:04:00 PM] Process Line = <1-1-0-1 WO NA IP IP=172.20.6.40>
[12/31/2009 8:04:00 PM] Fuzzy match detector start detecting prompt. String1=1-1-0-1wonaipip=172.20.6.40 String2=unsaved:lab_pfa>
[12/31/2009 8:04:00 PM] Process Line = <END>
[12/31/2009 8:04:00 PM] Fuzzy match detector start detecting prompt. String1=end String2=unsaved:lab_pfa>
[12/31/2009 8:04:00 PM] <-------------- vPrompt received
[12/31/2009 8:04:00 PM] Process Line = <UnSaved:Lab_Pfa>>
[12/31/2009 8:04:00 PM] Fuzzy match detector start detecting prompt. String1=unsaved:lab_pfa> String2=unsaved:lab_pfa>
[12/31/2009 8:04:00 PM] SendNextCommand Done: Disconnecting
[12/31/2009 8:04:00 PM] TimerTick: mstrData=<UnSaved:Lab_Pfa>> State=3 - Connected to server - idle
[12/31/2009 8:04:00 PM] Pending Disconnect = True
[12/31/2009 8:04:00 PM] Disconnected - From: 172.20.6.40
Anyone can help?
Thanks.
