9.5SP4
In Orion Report Writer, there is a tab labeled Field Formatting. One of the options is Column Width.
After executing an SQL query, I can highlight a field in the left hand column and customize the width by typing in a value or dragging the column to the desired size. After making a change, I click save.
Problem is - the setting doesn't stick - it defaults back when a new SQL query is run or the web interface is used to display a report.
Am I doing something wrong or is this a bug?
