We are showing a critical alarm on both nodes of an HA sql cluster...however the cluster is healthy. The fault is from the last failover event which occurred during maintenance due to installing windows updates. There have been no failures since..and the cluster event log appears clean...however the component remains in a critical state. How do we reset this? And/or is there something we need to do after planned maintenance to prevent it from going into a critical state?
Thanks!
