Hello,
in NPM 10.1.1 I have created a custom poller, that recieves decimal values (Disk: Written Bytes/sec).
For some reason, NPM seems to ignore the delimiter and instead of 1064685.97540109 it uses the value 106468597540109 which is obviously far too much. This results in TB/sec troughput for a SAS Disk as you can see here.
To avoid this, I use a transformation with function Truncate( ,0), which should produce integer values.
In the test, it behaves as it should - but when I add the transformation to my Node Details page, I still see the huge values.
What am I missing?
