I have a file server and sql cluster. I'm currently monitoring one sql cluster by the virtual cluster IP address (192.168.101.x) which is in the dmz. It's monitoring as expected. However, when attempting to monitor the other clusters (192.168.101.x) it doesn't respond to the SNMP walk or node add in Orion. I can ping the hostname and IP address.Any thoughts how to monitor the virtual cluster ip for the two other clusters?
