Hi there.
We recently started using some pulldown options in customer properties (node). Along the way we realized that there are a few spelling mistakes or items missing complete model numbers that we wish to modify. Our only options are to delete the items from the pulldown and then re-add the proper spelling it appears, which means those nodes effected now do not have those values any longer
Is there another way to search/replace the value that is used in the pulldown menus without losing important data? We are using some of these custom properties in our alerts as trigger conditions.
There is probably a way to do it in the database manager but I have no idea where to find the correct fields etc. If someone has a database query that would search for "APC 7900" and replace that option with "APC AP7900" in the custom property called "Equipment" that would be a huge help to me!
More and more I'm learning that to run the Solarwinds platform you really need a DBA on staff - in all seriousness I think in the marketing material that SW should put that as a system requirement.
Paul
