Hi All,
I have created a view in Solarwinds to display a graph that shows component data (see screenshot for reference). I used Custom Object Resouce and selected Component that is assigned to a specific node.
Then I assigned the created view to a specific device type. What happens was for example I assigned that ATS: Output Power to Node component to node A it displays correctly but when I view another node for
example Node B it also show the graph take from Node A. If I changed it to node B, the object source in A also changed. Is there a way that the component data will be show in a graph depending on the node.
For example if I select Node A, it will show the graph showing statistic data from Node A, also if I click Node B, it will also changed the graph show the statistic data from Node B.
