I am using a device template that, when tested in device properties, works great. However, when I try to download the config I get ""Connection Refused". I have attached the template and session trace. PLEASE HELP!
Hi ds2acrvet,
Try disabling the paging, i.e. set the value of the Reset command to "paging no enable" according to
http://www.silver-peak.com/static/UserDocuments/CLI_R3-3_RevI/wwhelp/wwhimpl/common/html/wwhelp.htm#context=CLI_R3-3_Rev…
Regards,
Jiri
Thanks for pointing me in the right direction - the command on the newer versions is "no cli session paging enable"
