I am currently using TCP port monitor to check if some of the TCP ports are available. I did not set any threshold on this so I must be using the "template defined" threshold. When I try to search for that value, I could not find it. How does solarwinds APM defined this threshold? Does it do a baseline of the TCP syn - ack response time to determine the proper response time? Because sometimes we do get alerts on this but I could not see the thresholds. When I open the template we are using the warning and critical thresholds are empty. Also there is a Response Timeout on the Orion General Threshold, is that what's being used? I just don't understand how it works because the Admin guide does not tell me. Any idea?
