Hi
I am looking for some advice on our Daily Maintenance Plan.
The task is failing every day with the same error message 'Executing the query "ALTER INDEX [CI_HostName] ON [dbo].[OrionServers] ..." failed with the following error: "The index "CI_HostName" (partition 1) on table "OrionServers" cannot be reorganized because page level locking is disabled.". Possible failure reasons: Problems with the query, "ResultSet" property not set correctly, parameters not set correctly, or connection not established correctly.'
I have looked into this and it would appear the table OrionServers has a clustered index called CI_HostName this index does not have the 'Use page locks when accessing the index'. I believe changing this setting would remove the error above but would like to confirm it is OK to do this?
Please advise
Regards
Daniel
