Does, or can, Orion support SQL mirroring? If yes, how is it set up? If no, can it be added as a feature Request?
Hi eanthes--
Here are some posts I found on mirroring. Can they help your specific installation? If not, post back and I'll make sure the PM sees it.
M
Hi Ernie--
I'll let the product manager have a look at this and get back to you.
Thx,
Mirroing SQL is something separate to Orion in the fact that the mirroing is done at the database level. Whether this is using log shipping, DBsnapshots or the various 3rd party apps available.
You dont give your reasons for mirroring, but in most situations mirroring is performed to place an instance of the SQL database at a remote DR location. Whether there is a mirrored, but service disabled, installation of Orion, which in the case of DR failover, the DR Orion will be configured to use the mirrored SQL server. When failing back to the primary site, the database is synchronised back to provide a consistent data collective.
Ernie,
PM me via thwack and we can talk offline regarding some options for you to look into and I can gather more of your requirements.
