I removed mounted path from a server and now it shows as erroneous within solarwinds monitoring.
I'd like to remove them from monitoring properly but all I can find are SQL scripts to run against the solarwinds database.
Is there a way to properly remove a mounted path properly from monitoring through the interface?
