citrixHi Folks,
I now started using SAM and ran into a Problem regarding the "Citrix XenApp 5.0 ICA Session WMI counters" template. When I Test the template against a terminal server it tells me "Test failed with unknown status on <servername>: HResult: The specified object is not found on the system." We're using Citrix XenApp 5.5 and I added the Terminalservers via SNMPv2. The other Citrix Templates (e.g. Citrix XenApp 5.0 Core WMI counters) are running just fine. Any idea how I get the ICAsession template up and running?
Thanks and regards,
Sven
