How would we monitor SSL Certificate expiration on an ACE load balancer? Is this possible?
You can use the SSL Certificate Expiration Date Monitor in SAM, assigned to your Cisco ACE, and configured for the HTTPS website you'd like to monitor the SSL certificate expiration on.
Just curious if anything came about from this...I'm in the same boat - looking to monitor ssl certs on the ACE. The command run to show them now is "show crypto cert all", but some certs dont have a website tied to them so the SSL cert monitor for sam wont work.
If the certificates aren't accessible via HTTPS then SAM cannot monitor them. You might however be able to work some magic using Network Configuration Manager.
Hi aLTeReGo
Please let me know how can we get report of alert for certificate expiration on routers using NCM.
That would be a question better suited for the Network Configuration Manager forum.
