We are testing the hardware monitoring of network devices in SW NPM, but we have an issue were the hardware simply disappears in solarwinds if we for instance unplug a powersupply, doing an SNMP walk shows the following:
18-12-2018 09:33:31 (2 ms) : SNMP V2c
18-12-2018 09:33:31 (2 ms) : Walk 1.3.6.1.4.1.9.9.13.1.5.1.3
18-12-2018 09:33:31 (6 ms) : 1.3.6.1.4.1.9.9.13.1.5.1.3.1016 = "4" [ASN_INTEGER]
18-12-2018 09:33:31 (8 ms) : 1.3.6.1.4.1.9.9.13.1.5.1.3.1017 = "1" [ASN_INTEGER]
So the switch is actually reporting correctly in SNMP, but solarwinds shows the following:
So the faulty power supply is no longer present, same goes for the FANS, as you can see in the screenshot one of the fans was pulled from the switch, but again the fan simply magically disappears in SW.
Any good idea's on how to fix this??
