We have recently upgraded our Core network infrastructure to Cisco Nexus 7010 Switches. Since the upgrade I am unable to get Orion Netflow to see the data, when I look at the Netflow Sources it shows the two switches but they have never seen any netflow data.
The event summary shows: -
NetFlow Receiver Service [xxxxx] is receiving a NetFlow data stream from an unmanaged interface on xxxxxxxxx. The NetFlow data stream will be discarded. Please use Orion Node Management to manage interface '#81' in order to process this NetFlow data stream, or just use Edit this device.
All interfaces on the Nexus are being monitored by NPM with a read/write community string.
The switch config is: -
ip route-cache flow infer-fields
ip flow ingress infer-fields
ip flow-cache timeout active 1
ip flow-export source Vlan1
ip flow-export version 5
ip flow-export destination xxxxxxxxx 2055
I know the Orion server is constantly seeing streams from the IP's because I have capture port 2055 on Wireshark and I am seeing a constant stream of data.
Any idea's?
