It doesn't appear that the SQL database has URI. I'm hoping to run a SQL query, but have it return a value for the URI (there are syntax limitations in SWQL, so I'm going to SQL).
swis://{pollingengine}/Orion/Orion.Nodes/NodeID={nodeID}
We've upgraded and migrated our Orion instance multiple times, so the value for my {pollingengine} is an old name for our original primary polling engine. Where is it getting that from? Anyone know what tables/columns would be used in a SQL SELECT to get:
- Node URI
- Interface URI
- Volume URI
