Hello all,
I have the Orion Performance Monitor and the Netflow running without any problems with my Cisco and Juniper devices.
Today I wanted to use the Netflow on VMWare ESX to monitor the network flows and run into the following problem:
The Netflow is running on the VMWare and it is sending to the Netflow collector (checked with sniffer), but they are discarded because I can not add the interfaces to the Orion Performance Monitor. As far as I understand Orion needs to identify the interfaces from which the Netflow packets are coming via SNMP beforehand, so it must be added via the Performance monitor. The SNMP is running on the VMWare ESX server (e.g 10.10.10.1), but the Netflow packets are marked with the IP of the VMWare kernel (10.10.10.2), so the SNMP and the Kernel are using different addresses, and there seems to be no way to add the virtual switch interfaces to the Orion, so the Netflow is not working (just discarded at the Netflow collector).
I hope somebody already is using VMWare netflow and Orion successfully, please help me to find a solution as we have a big need for this Netflow data.
Best regards,
Andreas Plaul
