Hi all,
Is there a way that with the HTTP Monitor I can configure it to only warn me if 2 consecutive polls fail and go Critical on 3? I currently poll every 300 seconds and for one server we occasionally do not get a response although there does not appear to be a problem with the server and users are working fine. It returns to Up again on the next poll.
I'd like to poll more frequently but only warn/fail on successive failures. The Warning and Critical values allow me to select for "Greater than", "Greater than or equal to".... for a Single Poll, x Consecutive or X of Y.
I believe I will need to select a value and select "2 consecutive" for Warning and "3 consecutive" for Critical but am not sure what to select to alert on. Does a failure of the HTTP Monitor return a value or 0? Of 1? or something else? (and how would I go about working this out myself in future?)
Lee
