Fresh meat here (was a What's Up Gold user)
I have a device I am attempting to create a graph based on a MIB value.
The device is a TC Comm ethernet switch. Solarwinds does not heave the exact MIB. The vendor has supplied me with their MIB and the OID I need to access.
I built a universal poller to for this MIB - see attachment-1
I assigned the poller to the specific TC Comm switch interfaces and successfully received a valid response - see attachmnet-2
I assigned the poller to a specific web display where no values are plotted- see attachment-3a and 3b.
Opened a ticket with Solarwinds and they said the MIB shows is is a string octet and I need to build a transform. Here is the specific section of the MIB with the OID
-- 1.3.6.1.4.1.13928.16.5.4.1.1.2.1.7
ethRMONBWStatusSummRxBU OBJECT-TYPE
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
DESCRIPTION
"The read-only integer value index of ports on this unit."
::= { ethRMONBWStatusSummaryEntry 7 }
So I got into building a transform but am unsure what to do since the poller is returning a correct value, but the transform returns 'Error' - see attachment-4a and 4b
Any ideas?
Thank you
