Hello all,
I'm in a situation where I have two Solarwinds environments, existing has IPAM IPX (and corresponding licensing for NPM/NTA/NCM etc) in Production, and a new "to be Prod" environment with IP1000-level IPAM licensing-to-cover.
(Yes We're building the second environment to replace the first environment.)
The network manager would like to start using the IPAM on the replacement system ahead of us "officially" cutting over the entire environment, and it's pretty clear if we do that, the IP address count will quickly exceed the IP1000 limits.
Question is... Can I swap the licensing between these two environments for IPAM only, leaving the remaining NPM/NTA/NCM licensing in both deployments as-is, and succeed in using IPAM with the IPX license level on the newer environment, while putting the IP1000 on the other?
(Obviously, I realize the leftover IPs on the first environment will exceed the count.)
I've tried searching around, reviewed IPAM license docs, and I couldn't find a straight answer to this question.
First post, please forgive me.
Thanks.
Byron
