I'm trying to setup a view that has the Top XX Conversations and what I would like it to have the Top XX Conversations only show me the top conversations for the devices that the view is limited to. Right now whenever I put the limitations on the view the Top XX item throws an error similar to the following...
Failure retrieving data - refresh your browser (F5) to try again.
If the problem persists, see C:\Documents and Settings\All Users\Application Data\SolarWinds\Logs\Orion\OrionWeb.log for detailed information.
When I look at the OrionWeb.log it tells me that I don't have permission to a node (i.e. N.213). When I look up the node it's one I don't want in the view.
I was hoping someone might have either done this or may have some ideas to get this working.
Darrin
