Background Info:
Started to update VoIP to 2.1 this morning. Stopped all services on all pollers (2 main, 1 HSB). Started install on 1st poller and installed as an Upgrade from 2.0. Install completed without problems and config wizard started up.
Ran configuration wizard with default select values after install and continued. Configuration wizard go to "Updating Orion Database: Processing VoIPDatabaseScheme.dbConfig file..." It hung here for about 4 minutes.
Killed process since there was no CPU action or memory change over the 4 minute period. Restarted install and configuration wizard with the same settings and selections.
Configuration wizard hung on the same step. This time I let it run for almost 15 minutes with no CPU change or Memory change.
Attempted to roll back to VoIP 2.0 by running install for VoIP 2.0 SP2 followed by SP3 Update. All went well ran configuration wizard successfully and restarted services on all machines.
Let services initialize and stabilize for about 5 minutes then viewed Orion Website to make sure all application modules were in working order.
Clicked on VoIP module and received Orion Website error. Clicked on APM Module and received APM could not reach APM on machineName 17777.
Attempted to run configuration wizard to correct these issues since previous (prior to this morning) installs were the only ones running.
Configuration wizard began with only options for VoIP, APM, Wireless modules. Clicked all three to correct and corruption and began wizard.
Configuration wizzard blows up with the following error. "Database configuration failed: Error while executing scritp - There is already and object named 'PK_VoipCCMPhoneStats' in the database. Could not create constraint. See previous errors."
Help. Orion is down and maintenance window is shrinking fast. Please respond.
Thanks in advance.
