I am having difficulty starting the Orion NPM. I cannot seem to log into the Orion Web Console as noted in the Quick Start Guide as well as my notes from class. I am using default userID & PW . I noticed several ip addresses in the address bar of Internet Explorer. They were:
When I use either of the above address, I get the following:
i Internet Explorer Cannot Display the webpage
Most likely causes:
· You are not connected to the Internet
· The website is encountering problems
· There might be a typing error in the address
What you can try:
· Check your Internet connection. Try visiting another website to make sure you are connected
· Retype the address
· Go back to previous page.
· More information
Did I miss something?
Dave
