Hi there,
It appears that an alert has been setup that goes like this (SWQL):
SELECT E0.[Uri], E0.[DisplayName]
FROM Orion.VIM.Hosts AS E0
WHERE ( E0.[MemUsageThreshold].[CurrentValue] = E0.[MemUsageThreshold].[Level2Value] )
I managed to expand on this, to return some more details, so now I can see the current memory utilisation and the two thresholds (critical and warning respectively):
SELECT E0.Uri, e0.HostID, E0.HostName, E0.NodeID, E0.MemUsageThreshold.CurrentValue, E0.MemUsageThreshold.Level2Value, E0.MemUsageThreshold.Level1Value
However, someone has asked me to tweak these thresholds on a few hosts and despite several hours of investigating in VIM and in SQL with the VIM_Host* tables,I am no closer to finding where I can adjust these thresholds, in Orion or by SQL.
The values from E0.MemUsageThreshold.CurrentValue, E0.MemUsageThreshold.Level2Value, E0.MemUsageThreshold.Level1Value appear to be very similar to those in SWQL table VIM_HostThresholds, which uses only one ID column, InstanceID.
I assumed that one of the VIM_Host* tables would tie back to the VIM_Host*Threshold tables, but these tables use an InstanceID, which I have been unable to tie back to any other table.
I have listed and search all table with InstanceID as a column name
Select table_name
From information_schema.columns
Where column_name = 'InstanceId';
Results in:
table_name
VIM_ClusterThresholds
VIM_ClusterCpuLoadThreshold
VIM_ClusterMemUsageThreshold
ESI_Instance
VIM_DatastoreThresholds
SNI_AlertIncidents
VIM_DatastoreIOPSTotalThreshold
VIM_DatastoreIOPSReadThreshold
VIM_DatastoreIOPSWriteThreshold
VIM_DatastoreLatencyTotalThreshold
VIM_DatastoreLatencyReadThreshold
VIM_DatastoreLatencyWriteThreshold
VIM_HostThresholds
VIM_HostCpuLoadThreshold
VIM_HostMemUsageThreshold
VIM_HostNetworkUtilizationThreshold
VIM_VirtualMachineThresholds
VIM_VirtualMachineCpuLoadThreshold
VIM_VirtualMachineMemUsageThreshold
VIM_VirtualMachineCpuReadyThreshold
VIM_VirtualMachineIOPSTotalThreshold
VIM_VirtualMachineIOPSReadThreshold
VIM_VirtualMachineIOPSWriteThreshold
VIM_VirtualMachineLatencyTotalThreshold
VIM_VirtualMachineLatencyReadThreshold
VIM_VirtualMachineLatencyWriteThreshold
VIM_VirtualMachineNetworkUsageRateThreshold
DPI_Thresholds
DPI_ApplicationsThresholds
NodesThresholds
NodesCpuLoadThreshold
NodesPercentMemoryUsedThreshold
NodesResponseTimeThreshold
NodesPercentLossThreshold
NodesForecastCapacity
NodesPercentMemoryUsedForecastCapacity
NodesCpuLoadForecastCapacity
Thresholds
WirelessHeatMap_MapPoint
ForecastCapacitySettings
WorldMapPoints
InterfacesThresholds
VolumesForecastCapacity
InterfacesInErrorsDiscards
VolumesPercentDiskUsedForecastCapacity
InterfacesOutErrorsDiscards
InterfacesInPercentUtilization
InterfacesOutPercentUtilization
InterfacesForecastCapacity
So far, I have found nothing in there to allow me to tie InstanceID back with a host
I am guessing there is a lookup table somewhere I am missing, does any one have any ideas?
Or how to avoid SQL entirely and update these thresholds using the UI?
