I am trying to create a report which will show me total traffic by IP group (or range) and had been using the NetFlowSummary1 table but not sure that it is getting all of the data.
Can someone explain the difference between the NetFlowSummary1, NetFlowSummary2, NetFlowSummary3 tables and the NetFlowSummary view?
If I wanted to run a total byte traffic report for the past 30 days on a range of IP's which one would I use as the source?
Thanks in advance for the help.
