Can anyone guide me on the configurations to monitor Oracle DB ?
What credentials do I need? The OS or Oracle itself?
After that what else?
I followed the http://www.solarwinds.com/documentation/apm/docs/Configuring_and_Integrating_Oracle.pdf guide but still I am receiving ORA-12537: TNS:connection closed error.
Please advise.
Thanks.
The Template reference for Oracle Database covers the credentials required.
Credentials: An Oracle user name and password with read access to the Oracle views: dba_free_space, v$sysstat, v$rowcache, v$librarycache, v$sgastat, and v$session.
is correct. You will need Oracle credentials to connect to the Oracle database server. You will also need to ensure that you've installed the Oracle client on the Orion server. You can download the Oracle Data Provider for .NET (ODP.Net) from Oracle's website, or use the Basic Lite Oracle Client that's available for download through your customer portal.
Hi Michael,
I installed the Basic Lite Oracle client on the Orion server. I am required to key in the service name into the components right?
EXTPROC_CONNECTION_DATA =
(DESCRIPTION =
(ADDRESS_LIST =
(ADDRESS = (PROTOCOL = TCP)(HOST = mz051.asdf.com)(PORT = 1521))
(CONNECT_DATA =
(SERVICE_NAME = PLSExtProc)
For instance the above tnsnames.ora file for the specific server.
I will have to choose
Port Number - 1521
Destination Point Type - SERVICE_NAME
Destination Point Name - PLSExtProc
But still I prompt with Oracle returned an error. ORA-12537: TNS:connection closed error.
Please advise
Have you tried changing the "Oracle Driver Type"? Also, have you verified that the credentials you're using have adequate permissions in Oracle? I would also suggest reviewing the following document.
Configuring and Integrating Oracle. (PDF)
I hate to rez an old topic, but are these grants still all that are needed for Oracle 12c?
I had our DBA Team provide them but I cannot get the Tablespace queries to work, says the table or view does not exist. According to them, this account needs "Grant select on sys.v_$tablespace" in addition to those listed.
Is that the case? If so, can the document be updated to reflect that? I need documentation in case an auditor wants to know why this account has these rights.
