The startup config is putting a number in front of every line, So every line shows as changed ?
Any help would be great, thanks
Guy
Startup Config Running Config
001 1: !Current Configuration 001 !Current Configuration
Hello.
I have a few PCT6200 switches still managed by NPM, NTA and NCM
what are you trying to do with NCM on these switches? Just view config differences?
startup configs on the Dell is a bit chaotic with the line numbers. I usually just use running config to view differences
every time you change configs, the code gets pushed down a line, so if you were to add in a line, say add a new user account, the new code would be inserted into the next line, and change the numbers.
I have seen that with my PCT6200, 7000 and N3000 series switches. I think that is just how the Dell Network OS works.
